Snmp polls failing
alburton
I am having a problem with the new Cisco ISR's 2811 and snmp. When a Frame-Relay link is running at high utilisation snmp polls to the router fails. We experience this issue with different Access and CIR rates. We have configured the routers with and without CBWFQ but same issue. Anyone seen this before ?
steve.busby
Level 5
Level 5
If your links are saturated, then yes, SNMP will fail because it has a lower priority then your normal TCP traffic.
