snmp trap to smtp
kenglim84
Do anyone know how to convert the snmp trap to smtp(email). I need it as an alert to my email account when I plug out the device.
I using ciscoworks LMS 3.1
Joe Clarke
This may not be possible with LMS. While LMS does come with the DFM application which does fault monitoring, it does not process all device traps. A list of the traps that DFM handles can be found at http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_device_fault_manager/3.1/user/guide/TrapFwd.html .
If your trap is processed by DFM, you can set up an email notification by first creating a notification group under DFM > Notification Services > Notification Groups. Then, assign that group to a notification subscription under DFM > Notification Services > E-Mail Notification.
