snmp traps to lms 4.2 ,
Ibrahim Jamil
Level 6
Level 6
Hi Guys
i have configured one of my device for testing purpose to send SNMP traps <ex,Link up/down to my LMS 4.2 , i have adminstravily shuted down the uplink interface of the switch , however from the LMS side , I didn't see any thing , pls help me to trouble this issue
thanks
ibrahim
STEFFEN NEUSER
Level 4
Level 4
Hi Ibrahim,
Is your Windows/Solaris-firewall of LMS-server activated?  If yes, did you also opened udp162 at the Windows-firewall?
Traps you can see at Fault History of DFM (Monitoring => Events).
If the Windows SNMP-Trapd was running during LMS installation, LMS will move the trap listener to udp9000 silently until you configure LMS back to standard udp162 for SNMP traps.
Steffen
AFROJ AHMAD
Hi Ibrahim,
Go to ::  Admin > Collection Settings > Fault > Fault Monitoring Device Administration
You need to make sure the device is in KNOWN state under DFM.
If above is correct then you can check suggestion given by Steffen..
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
