SNMP V3 and Ciscoworks 2.6
john.cooper
I'm having a problem moving from SNMP v2 to SNMP v3 on our Cisco 3560 switches to talk to Ciscoworks LMS 2.6.
I've entered the commands below into the switch:
snmp-server view campus mib-2 included
snmp-server group groupname v3 auth read campus write campus
snmp-server user Username groupname v3 auth md5 password
snmp-server trap-source VlanXXX
snmp-server location London building number street floor ID
snmp-server chassis-id switchhostname
When I try a credentials check from Works I get the following error in the credential verification report under SNMP v3:
Setting v3 Param mode to authNoPriv. querying sysLocation.obtained exception while g/setting sysLocation com.cisco.nm.lib.snmp.lib.SnmpException
Any ideas or pointers how I can investigate the cause of this?
JC
yjdabear
If the configs are as shown, the second line probably overrides the previous one, so user Username has a blank password:
