06-18-2019 06:12 AM
Hi there,
I have a customer running Catalyst WS-C2960+24TC-L with IOS Release 15.0(2)SE5.
He would like to run SNMP v3 with following:
snmp-server user snmpuser GROUP-RO v3 auth sha-256 xxxxx priv aes 256 yyyyy
unfortunately I am not able to find any configuration option for auth sha-256, only for auth sha. On the other side i can configure aes 256.
Ist auth sha-256 supported with the running IOS Release?
If yes, how do i have to configure it?
If not, please indicate the minimum release number, wher sha-256 for snmpv3 auth is supported
Thanks a lot
Heinz
06-18-2019 08:22 AM
05-03-2023 04:26 AM
Helpful ! Because of still using insecure obsoleted / depreciated auth. meth. / algorithms I think I will consider in making purchasing decisions.
br
