03-13-2014 11:49 PM
I need to set up some parameters on SG, SF series switches with snmset command from NET-Snmp tools. It is possible for me to set up some simple parameters like ifAdminStatus of the port. The command to do this looks like:
snmpset -m ALL -v 3 -u secName -l authPriv -a sha -A secret -x des -X secret switchIP ifAdminStatus.49 i 1
But I'd like to get static addresses table. I can snmwalk it with command:
snmpwalk -v 3 -u secName -l authPriv -a sha -A secret -x des -X secret switchIP iso.3.6.1.2.1.17.7.1.3.1.1.4
and it returns me the key->value list:
iso.3.6.1.2.1.17.7.1.3.1.1.4.101.60.151.14.68.239.217.64 = INTEGER: 3
iso.3.6.1.2.1.17.7.1.3.1.1.4.101.120.132.60.0.230.199.52 = INTEGER: 3 etc...
where iso.3.6.1.2.1.17.7.1.3.1.1.4 - dot1qStaticUnicastStatus, 101 - VLAN id, 60.151.14.68.239.217 - mac in decimal form, 64 - port number and 3 - status (permanent). These are the only occurence of this information in MIB list.
Is it possible to set up static addresses table with snmset?
03-14-2014 12:17 AM
Are you facing issue with ONLY this OID iso.3.6.1.2.1.17.7.1.3.1.1.4 from this MIB Q-BRIDGE ?
Thanks-
Afroz
03-14-2014 12:33 AM
