SNMPSET Shutdown Interface
cassio.gomes
Level 3
Level 3
Hi All...
How can I use SNMPSET to shutdown router interface from software ?
If possible, put a example with OID and MIB.
CLRGomes.
nhabib
Level 11
Level 11
You would have to set the ifAdminStatus .1.3.6.1.2.1.2.2.1.7 for that interface to 2 (down)
But first, you would have to figure out its index, so you would have to perform an snmpwalk of ifDescr
nhabib
Level 11
Level 11
Hi nhabib,
Thanks a lot, your message is perfect!
snmpset -v 2c -c public 10.1.1.1 .1.3.6.1.2.1.2.1.7.5 integer (value)
1 : up
2 : down
3 : testing
CLRGomes
