02-26-2014 07:16 PM
Hi Friends,
I would like to clarify some concerns related to SNMP.
SNMPv2 and SNMPv3 Use same MIB or Different
SNMP MIB is software/IOS dependent?
Consider that device is already managed by SNMPv2 and we are migrating it to snmpv3, so whether we have to change MIB from snmp tool.
Vivek Kumar
Solved! Go to Solution.
02-26-2014 07:23 PM
Hi Vivek,
SNMPv2 and SNMPv3 Use same MIB or Different >>>
SNMP v2 and V3 are the versions of SNMP , they use the same mib . but their difference in the way ,how they work
SNMPv3 is more secure than SNMPv2
SNMP MIB is software/IOS dependent? Yes
yes , depending in the IOS /IOS-xr / IOS-Xe code you are running .. MIB supports would be different.
No , you don't need to change anything on your tool as long as you tool supports SNMPv3 authentication types.
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
02-26-2014 07:23 PM
Hi Vivek,
Thanks-
Afroz
02-26-2014 07:32 PM
Thank You.
02-26-2014 07:25 PM
FYI ..
What is the difference between SNMP v2 and SNMP v3?
Main difference between SNMP v2 and SNMP v3 are the enhancements to the security and remote configuration model. SNMP v3 adds cryptographic security to SNMP v2. SNMP v3 replaces the simple password sharing (as clear text) in SNMP v2 with a much more secure encoded security parameters. Due to the introduction of new conventions for texts, concepts and new terminology, SNMP v3 looks different than SNMP v2 (even though there aren’t many changes).
Thanks-
Afroz
