I'm trying to model a cisco 2911 using SNMPv3 with authentication and encryption, however, it wont work.The config is exactly the same already running on an identical router (same IOS) but it fails to commuicate - SNMPv1 works fine:
KENSWO_D_CR291_01#sh snmp
189 SNMP packets input
0 Bad SNMP version errors
0 Unknown community name
0 Illegal operation for community name supplied
0 Encoding errors
250 Number of requested variables
0 Number of altered variables
23 Get-request PDUs
94 Get-next PDUs
0 Set-request PDUs
0 Input queue packet drops (Maximum queue size 1000)
285 SNMP packets output
0 Too big errors (Maximum packet size 1500)
0 No such name errors
0 Bad values errors
0 General errors
117 Response PDUs
96 Trap PDUs
SNMP Dispatcher:
queue 0/75 (current/max), 0 dropped
SNMP Engine:
queue 0/1000 (current/max), 0 dropped
0 Unknown Security Models
0 SNMP Invalid Messages
0 SNMP Unknown PDU handlers
0 Unsupported Security Level
1 Unknown User Names
1 Unknown EngineIDs
70 Not In Time Windows <<<<<<<<<<<<
0 Wrong MD5 or SHA Digests
0 Decryption Errors
debug snmp packet / detail shows the below error in the logs:
000642: Jun 26 15:37:49: SNMP: Packet received via UDP from 10.2.0.129 on Vlan4S
rParseV3SnmpMessage: not in lifetime failure
SrParseV3SnmpMessage: Failed.
SrDoSnmp: Packet not in Time Window
000643: Jun 26 15:37:49: SNMP: Report, reqid 2147483647, errstat 0, erridx 0
internet.6.3.15.1.1.2.0 = 71
000644: Jun 26 15:37:49: SNMP: Packet sent via UDP to 10.2.0.129
process_mgmt_req_int: UDP packet being de-queued
000645: Jun 26 15:37:52: SNMP: Packet received via UDP from 10.2.0.129 on Vlan4S
Config:
snmp-server group USER-GROUP v3 priv
snmp-server host 10.2.0.129 version 3 priv USER
snmp-server user USER USER-GROUP v3 auth md5 password priv des password
KENSWO_D_CR291_01#sh snmp engin
Local SNMP engineID: 800000090300000000000000
Remote Engine ID IP-addr Port
KENSWO_D_CR291_01#sh snmp user
User name: USER
Engine ID: 800000090300000000000000
storage-type: nonvolatile active
Authentication Protocol: MD5
Privacy Protocol: DES
Group-name: USER-GROUP
Has anyone seen this or can advise further??
Phil
Solved! Go to Solution.
This error points to specifying a bad engine time when querying your device. How are you doing the querying? Are you using the same exact command line from the working device? If so, you can't use the same engine ID, boots, and engine time. Note: the way SNMPv3 typically works is that the first query will be without an engine ID, boots, or engine time. The device will reply with a REPORT packet that contains the authoritative values. The manager will then re-request the objects with the appropriate engine values.
If you're seeing repeated time window violations, you may have a bad SNMP engine cache on your manager.
Hello - yes it has the same engine ID shown in sh snmp engine command - I see this can be changed using a local engine ID (see below), but what hex value should be used per device to make sure this is unique (I tried using a hex conversion of an IP on the device but it stated it needs 10 digits)?
snmp-server enigne local <10-digit-hex-value>
Is there a standard policy to follow?
Phil
Did you change the engine ID originally? The engine ID needs to be unique across all devices. By default, this will be the case (unless you're seeing a bug). You should never copy and paste the SNMP engine ID config from one device to another. If you did this, configure the following:
no snmp-server
Then reload. When the device reboots, reconfigure your SNMPv3 parameters WITHOUT changing the engine ID. That should give you a unique value.
used a MAC address from an interface on the router as the snmp engine ID - all working - thanks.
