snmpv3 error on 3750s
markschnabel
Level 4
Level 4
we apply the following commands on 2 different 3750s running 12.2.46 and received the following error:
%PARSE_RC-4-PRC_NON_COMPLIANCE: `snmp-server user xxxx xxx v3 auth md5 xxx priv des xxx access 9
-Traceback= DA7DA8 DA84F4 D30DE0 D3242C D32784 D5F73C 1813A88 1805B08 9BBFD4 9B2BCC
message decoder states it is a internal software error. Is this normal or should a tac case be opened
thanks in advance
Lucien Avramov
Level 10
Level 10
Can you post a show version?
There is a defect (on 12.2.46) :
CSCsh85522 SNMP-Sever user CLI throwing trace back messages
Are you able to poll SNMP with no problem from your NMS server?
5 Replies 5
Joe Clarke
Post the show ver from this 3750.
Lucien Avramov
Level 10
Level 10
yes, we are able to poll without issue.I did a test poll from CW
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 21-Aug-08 15:43 by nachen
Image text-base: 0x00003000, data-base: 0x01880000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
GOX007CAS uptime is 16 weeks, 23 hours, 16 minutes
System restarted at 15:43:23 EDT Tue Jun 23 2009
System image file is "flash:c3750-ipservicesk9-mz.122-46.SE/c3750-ipservicesk9-mz.122-46.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750-48P (PowerPC405) processor (revision K0) with 118784K/12280K bytes of memory.
Processor board ID FDO1145X0W2
Last reset from power-on
2 Virtual Ethernet interfaces
144 FastEthernet interfaces
12 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1E:4A:BD:36:80
Motherboard assembly number : 73-9675-11
Power supply part number : 341-0029-05
Motherboard serial number : FDO1145012A
Power supply serial number : LIT114005HC
Model revision number : K0
Motherboard revision number : B0
Model number : WS-C3750-48PS-S
System serial number : FDO1145X0W2
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : FDO114109MZ
Top Assembly Part Number : 800-25858-03
Top Assembly Revision Number : J0
Version ID : V05
CLEI Code Number : COM1W00ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
1 52 WS-C3750-48P 12.2(46)SE C3750-IPSERVICESK9-M
* 2 52 WS-C3750-48P 12.2(46)SE C3750-IPSERVICESK9-M
3 52 WS-C3750-48P 12.2(46)SE C3750-IPSERVICESK9-M
Switch 01
Switch Uptime : 16 weeks, 23 hours, 6 minutes
Base ethernet MAC Address : 00:1E:13:B7:CB:80
Motherboard serial number : FDO1144077H
Power supply serial number : LIT114003WM
System serial number : FDO1145X02L
SFP Module revision number : A0
SFP Module serial number : FDO1143046X
Top assembly part number : 800-25858-03
Top assembly revision number : J0
Version ID : V05
Configuration register is 0xF
As Lucien pointed out, this is CSCsh85522:
Symptom:
A "%PARSE_RC-4-PRC_NON_COMPLIANCE" error message and traceback may be
generated while executing snmp-server user testuser
testgroup v3 auth md5 authpass priv des privpass
Conditions:
This symptom is observed when the encryption type used is 'des'. This is
because of the ambiguity between des and des56, which is a hidden command.
Workaround:
This happens only when the command is given for the first time.
However, note that the error message and traceback do not have an impact on
the functionality of the platform. The messages are just warning messages
from the Cisco IOS process scheduler, indicating that the process is not able
to process all the events before the process suspends.
yes..thank you!
