SNMS 1.5
jricho
Having trouble installing ciscoworks 1.5. The initial splash screen appears and when you click install it just hangs. This is via the CD and from a local hard disk. Also tried installing via Terminal Services console and get error message regarding not being a supported operating system..?
Does anyone know if Small Network Management Server 1.5 supported on Windows 2003 "R2"
thanks.
Joe Clarke
SNMS 1.5.1 is supported on Windows 2003 only (not R2). SNMS 1.5 (without the .1) is not supported on Windows 2003. See http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cwsnms/1_5/snms15rn.htm for more details.
