Software distribution fails with SWIM1113
Device will be rebooted.
SWIM1113: Device Reboot operation failed or Reboot Verification failed.
The device is not running the new image after it is rebooted.
Verify the configuration used to load the new image. Verify whether the new image exists on the device in a valid Flash partition
the software distribution , i select image  for upgrade for router 1841  and select reboot immediatly after downloading so my device take new image but can not reload with new image ...
please help me .
12 Replies 12
AFROJ AHMAD
Hi ,
Try to increase the telnet timeout.
The timeout setting can be changed in: Admin > Collection Settings > Config > Edit the Inventory/Config Timeout and Retry Settings
Select the device and click on 'Edit device attributes'. On the new window click on 'Inline Edit'.
Then increase the 'Telnet Timeout' to 120. Click 'Modify' and then 'Apply' on the previous window.
Then try a new job.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
i change telnet time out  to 800 secend
i think that your answer not true . because i have same problem yet
change the settings back to what it was
Kindly enable the debugging fro SWIM (admin>debug settings)
re-run the job and share the swim_debug.log (NMSROOT/CSCOpx/log)
and Job log.
Thanks-
i take snapshot from screen , please check it
thankss
Hi ,
logs are incomplete, if there are some security reason , you can't send the complte logs then kindly raise a new tac case for assistance.
send the compelete job folder and
Swim_Debug.log  ( clear the swim_debug log before running the swim job)
NMSROOT/CSCOpx/log>logrot_trunc swim_debug.log
Thanks-
i test again , and upload complete log
log location : /var/adm/CSC0px/files/rme/jobs/swim/1919
chek it please ,,, thanks
I can see timeout error and LMS is not able to reload the device..
Increase the telnet timeout to 160 and SNMP timeout to 20 and SNMP retry to 3 and check the issue:
Thanks-
Afroz
i change telnet time out = 600
snmp time out = 100
snmp retry = 10
i can not solve this problem
I'm going crazy
the above timeouts are too much..
Is this happening on all the devices ? Can you try it on a different device (change the timeouts to Original ) ?
Thanks-
i change time and increase it  .
i test just on one device (router 1841) ,, i check another device and report to you .
i test on cisco switch 2960.
i have same problem . and device after reload , can not boot new image and hang up .
and i force to go  in rommon mode and transfer same image with manualy tftp for boot device .
Hi ,
what is the version of LMS you are running ?
did you checked the device Image Manually after the SWIM job for new IOS image ?
tried to update the device packages :
for LMS 4.x :
Admin > System > Software Center > Device Update
then select ::     Inventory Config And Image Management
for LMS 3.x:
CS >software center >device update
then select :: RME
tried the SWIM job after upgrading the device packages.
Thanks-
