SOLVED: Nexus ACL to limit SNMP between VLANS
ApjHouston
I'm not sure if I'm overthinking this but I'm not sure where to make the ACL for the following purpose...
We have a WiFi controller bridging VLANS directly into a Nexus switch, there has been SNMP traffic going to VLAN 5 from 50 but I only want VLANS 5 and 6 to have SNMP traffic.
I have previously worked with implementations where the traffic is passed into a Fortigate or Sophos and policies would be created to allow or block the traffic between VLAN networks. I have just started with this network and am having trouble working out how to utilize the Nexus properly for this configuration.
I initially went the route of trying an ip acl and found it's not going to work for the VLANs, I was reading about VACLs yesterday but also see some configuration for access-list copp.
For this purpose should I be looking to create a VACL or adjusting the copp acl with the VLAN 5 and 6 networks being allowed.
Thank you for any guidance.
ApjHouston
The Nexus does not support multiple access-maps, I had tested it working with multiple access-maps on a 2960 but I'm not sure which of my notes was the correct one so won't put it in here.
I had a ticket open with Cisco and Jason gave me a solution as below;
ip access-list BLOCK_SNMP_ACL
10 deny udp any any eq snmp
11 deny udp any any eq snmptrap
20 permit ip any any
vlan access-map BLOCK_SNMP
match ip address BLOCK_SNMP_ACL
action forward
stat
vlan filter BLOCK_SNMP vlan-list 50
I have tested it working with my MIB walk being blocked when applied and my HTTPS and ICMP tested still going through.
ApjHouston
I wasn't able to find an answer to this today, I used a test network with the configuration below but nothing is allowed through. When I try to use a sequence number for an access-map I get "ERROR: Mutltiple access-maps not supported". I was trying to think of a way to have the access-list only match the snmp part, allow the rest and I would just apply it to the VLAN I don't want sending SNMP.
Configuration I used that blocked everything;
ip access-list snmp-drop
10 permit udp any any eq snmp
11 permit udp any any eq snmptrap
exi
ip access-list permit-any
20 deny ip any any
exi
vlan access-map acl-snmp-drop
match ip address snmp-drop
match ip address permit-any
action drop
exi
vlan filter acl-snmp-drop vlan-list 51
I'll watch some videos tonight to try wrap my head around it but I'm open to suggestions.
Thanks again.
ApjHouston
action forward
stat
It was a pleasure working with you Apj!
Jason.
