Highlighted
ssh from HPNA to CISCO 3750 switch fails for backup
Hi Team ,
We have an issue taking the backup of Cisco 3750 switch from the HPNA GUI ,Rules are allowed on the firewall .
Note : SSH via HPNA CLI works .
Error Message on HPNA :
SCP failed [ConnectError: Can't open Telnet connection to 10.10.10.251  (port 23)]
SCP failed [Failure executing SCP command 'get': Failed to connect via SSH to 10.10.10.251  on port 22. Connection refused.]
Below is the configuration on the switch :
SW3750#sh ver | i bin
System image file is "flash:/c3750e-universalk9-mz.122-55.SE8/c3750e-universalk9-mz.122-55.SE8.bin"
SW3750#sh run | b line
line con 0
password 7 XYZ
line vty 0 4
logging synchronous
login local
transport input ssh telnet        transport output telnet
line vty 5 15
logging synchronous
login local
Regards ,
Chethan
5 REPLIES 5
Highlighted
VIP Expert
Do you have crypto key setup for SSH ?
what is the command you try to SCP ?
BB
*** Rate All Helpful Responses ***
Highlighted
Hi Balaji ,
I have executed this command --> ip http secure-server
I believe this will enable Crypto key ?
When we try to take the snapshot it try to ssh/telnet to device .
Regards ,
Chethan
Highlighted
VIP Collaborator
      Post the output of "show run | i aaa", "show run | i username" and "show ip ssh". Are you trying to connect via telnet or ssh.
Cristian Matei.
Highlighted
We use SSH to login , Please note I am able to login to switch using putty via ssh , but from HPNA GUI SSH is not working .
SW3750#show run | i aaa
no aaa new-model
SW3750#show run | i username
username admin privilege 15 secret 5 XXXXXXXXXXXXXXXXXXXXXXX
SW3750#show ip ssh
SSH Enabled - version 2.0
Authentication timeout: 120 secs; Authentication retries: 3
Highlighted
since you confirmed the SSH working using Putty, then this more to do with HPNA config, i see you are enabled SSH 2.0
have you correctly configured HPNA selection option SSH2 ?
BB
Content for Community-Ad
