SSLutil.pl stopped
KAROLY KOHEGYI
Level 2
Level 2
I would like to upload the signed certification to LMS 4.2.2.
After checking ( 4. option ) I choosed the 6. option  and press "y" for questions and the perl script is freezing.
( crmdmgtd had been stooped )
Any idea?
Thank in advance!
Vinod Arya
You shoud share the result of the Option 4 as well. Following are the most important things to be considered:
> The maximum supported public key value is 1024 bits. No 2048 bits cert is not supported.
> Cisco Prime does not support third-party certificates with "Subject Alternative Names".
For more details on this procedure, please check :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2/user/guide/admin/appendixcli.html#wp1073752
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
paul newman
Not sure I you are still having this issue but I hit it this morning and did the following to resolve.
1. Backup SSLUtil.pl
2. Open SSLUtil.pl in notepad and go to the section starting "if($response eq "5" || $response eq "6") {"
3. Replace the line "$date ='date';" with "$date =localtime;"
Run the script again.
