Stack 2960x with flexstackplus and 10G SFP+ uplink.
suporteUNISIM
I'm new with cisco equipment and I'm looking for some lights to solve an issue.
In 2960x switches (WS-C2960X-48FPD-L), Is it possible to convert a 10G SFP+ front uplink to a stack port without loose the connection on stack port of installed flexstackplus module?
Let me show my scenario. I have 3 2960x (in the same rack) stacked with flexstackplus and I have another 2960x in another build, and I would like to stack this separated switch using the 10G uplink with the others.
I saw that I can convert the uplink do stack port, but when I did it, my flexstackplus port stopped to work.
Thanks and best regards
marce1000
 Ref : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960xr/software/15_2_6_e/configuration_guide/b_1526e_consolidated_2960xr_cg/b_1526e_consolidated_2960xr_cg_chapter_01101101.pdf
When you convert a network port to a stack port, it continues to work as a network port without any impact
to the current running configuration until the next reload of the switch.
When you convert a stack port back to a network port, it continues to work as a stack port until the next reload.
After reload, the port comes up as a network port with the default configuration.
M.
Hi @marce1000
Thanks for your reply. I saw this document, but it does not solve my doubt.
I would like to work with my 2 flexstackplus port and my 10G uplink as a stack port at same time.
And when I convert my 10G uplink into stack port, my stack port from flexstackeplus stops to work.
