Stack Cisco Catalyst 3850 Series Switches
daocongtrung
Hello. Currently I am choosing Switch 3850 for my system.
Please tell me can I stack 2 devices "3850-48T-S" and cisco "3850-48XS-S" together?
I have read on the forum is possible. But I want to be sure.
10 Replies 10
luis_cordova
Hi @daocongtrung,
Look what I saw in the datasheet of that model:
Table 1.          Cisco Catalyst 3850 Series configurations
Model
Total 10/100/1000 or SFP or SFP+ ports
Default AC power supply
Available PoE power
POE budget with 1100W secondary PS
StackWise-480
StackPower
WS-C3850-24T
24
350WAC
Yes
Yes
WS-C3850-48T
48
WS-C3850-24P
24 PoE+
715WAC
435W
1535W
WS-C3850-48XS
48 1/10G SFP+
750WAC (front to back)
No
No
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/datasheet_c78-720918.html
I hope this information will be useful to you.
Thanks for your support.
I have read the datasheet again and found that the WS-C3850-24S supports StackWise-480.
So, Can stack Switch 3850-48T-S and WS-C3850-24S right?
Seb Rupik
As @luis_cordova points out the 48TS-S supports traditional stackwise contentions.
The 48XS-S supports stackwise virutal and can only be paired with another 48XS-S in this configuration.
As a pair the 48TS and 48XS cannot be stacked together.
cheers,
Seb.
I read the datasheet again and found that both the WS-C3850-24S and the WS-C3850-24S switches support StackWise-480. Can I use these 2 models?
Yes, any 3850 listed as supporting stackwise-480 can be physically connected via the stacking ports at the back of the switches.
cheers,
Seb.
Leo Laohoo
Not possible.
3850-48XS does not have stacking module at the back.
Hi Leo.
Yes I know. And I removed 3850-48XS.
I am talking about WS-C3850-24S and WS-C3850-24S. Both support StackWise-480.
Sorry, I made a mistake because of use copy.
I want to talk about two Switch "3850-48T-S" and "WS-C3850-24S".
I want to know can I stack two switches together.
As Mr. Seb Rupik said. We can stack all Cisco 3850 devices supported stackwise-480
3850-48T & 3850-24S can be stacked together.
Dear LOE.
