09-26-2024 01:08 PM
I have two Secure Firewalls (running ASA code) in a active/standby failover. Failover is working.
These intefaces are present:
Active unit is working as expected. The standby unit has on three interfaces the ip address 0.0.0.0.
This host: Primary - Active
Active time: 911 (sec)
slot 0: FPR-3105 hw/sw rev (1.0/9.20(3)) status (Up Sys)
Interface Management (192.168.200.10): Normal (Not-Monitored)
Interface Transit-Net (192.168.100.1): Normal (Not-Monitored)
Interface WAN1 (10.10.10.10): Normal (Not-Monitored)
Interface WAN2 (20.20.20.20): Normal (Not-Monitored)
Other host: Secondary - Standby Ready
Active time: 562 (sec)
Interface Management (192.168.200.11): Normal (Not-Monitored)
Interface Transit-Net (0.0.0.0): Normal (Not-Monitored)
Interface WAN1 (0.0.0.0): Normal (Not-Monitored)
Interface WAN2 (0.0.0.0): Normal (Not-Monitored)
Only the management interface has a standby ip address assigned. I guess this is the reason for it.
IP addresses of wan interfaces are public networks (/29) from each ISP (10.10.10.10, 20.20.20.20).
How do I "fix" this issue without needing a standby ip address?
Solved! Go to Solution.
09-27-2024 07:00 AM
The link would use the same name of the LAN interface, so you should use "failover link Failover-Link Ethernet1/7" and remove the "failover interface ip Stateful-Link" command please.
09-27-2024 07:02 AM
Please
Remove this
failover link Stateful-Link Ethernet1/7
Do
No Failover active
Check
MHM
09-27-2024 07:04 AM
I think if you connect eth1/7 to a switch and you configure the switch ports in trunk this would work without changing any config. However, to simplify this setup as already mentioned you can use a single physical interface. The configs on both firewalls would look like this:
Primary:
failover lan unit primary
failover lan interface Failover-Link Ethernet1/7
failover interface ip Failover-Link 192.168.110.1 255.255.255.252 standby 192.168.110.2
failover
Secondary:
failover lan unit secondary
failover
Hopefully I didn't miss anything.
09-27-2024 07:07 AM
He confirmed he use direct connect, but he use subinterface to make one interface work for both failover and state.
MHM
09-27-2024 08:50 AM - edited 09-27-2024 08:50 AM
I have reconfigurated the interface without two subinterfaces and it's working. Standby unit "receives" all ip addresses of the interfaces from the "failed" active unit.
P.S. do you know why subinterfaces cause this issue? Standby sees that it should become active but then "hangs" and doesn't "receive" the ip addresses?
Thank you both for your help!
