09-10-2021 01:08 PM
I'm trying to enter the the following command on the Nexus 5K switch and it's not working.
09-10-2021 01:13 PM
09-10-2021 02:11 PM
When I do a show run, I see the static route added. When I do a show ip route I don't see the static route added but I still see the default route of 0.0.0.0/0 192.168.7.10. Do I need to do anything different to add it there also? 192.168.8.0/24 traffic is still using the default route instead of the route I added.
09-13-2021 11:15 PM
Am I correct in understanding that the issue is that you do see the static route in show run but do not see the static route in the output of show ip route? If so my first question is whether the specified next hop of 192.168.9.10 is reachable. Posting the output of show ip route would be helpful.
09-14-2021 02:11 AM
I still stand on the orginal comment, is the next hop IP reachable to nexus ? (if not that rule applies)
10-17-2021 10:16 PM
Yes I can ping but my trace route fails.
10-17-2021 10:28 PM
My ip route shows but traffic still isn't taking that route. It's still trying to use the default route.
0.0.0.0/0 192.168.7.10(default route for all traffic)
192.168.8.0/24 172.16.205.10 - route I want this traffic to go on.
172.16.205.10 is the switch that DHCP is setup on for the 192.168.8.0/24 network.
