08-16-2013 01:01 AM
I noticed that when one of the devices being monitored in Cisco Prime 4.2 went down, it did not appear as "red" immediately on the Topology Services map. It appeared s red maybe after 30 mins or so. Can you help me adjust this?
Thanks in advance.
08-16-2013 08:55 AM
The topology services map is not designed to display real time status.
By default, LMS polls the entire network every 4 hours (in LMS 4.2, used to be every 2 hours) and updates the topology display based on that. You can add a subset of you devices in the Critical Device poller for more frequent checks but it is resource-intensive and not recommended for more than about 30 devices in total. (Reference)
The Fault and Event viewers can also be used for better visibility of device faults.
08-16-2013 05:11 PM
Hi Marvin,
Thank you for this information. Does it mean that Topology Services map is not reliable when it comes to device status on the network?
08-16-2013 09:43 PM
You're welcome.
It is reliable as of the last poll. It is, by design, not up to the minute.
09-05-2013 08:12 PM
Hi Marvin,
Our client is expecting a realtime monitoring of devices in Topology Services but since you said that is not up to the minute, can you somehow share a document from Cisco stating this?
Thanks in advance.
09-05-2013 09:24 PM
The link I referenced in my 16 August 1155 am postng is to the Adminstriation Guide. Note there in Table 6-3 it describes the default and critical deivce polling frequency I mentioned.
(click below to enlarge)
