STP Bandwidth Rules
Snifferson
Hi All,
Can anyone tell me:
I have 2 (a and b) redundancies. (a) goes through 1x 100baseT switch and (b) through 2x 1000baseT and 1x10baseT switches.
Will STP choose route a or b?
Effectively, I am asking, will STP choose the lowest average or does it do it a different way?
Joe
Michel Hegeraat
Level 7
Level 7
If you want to know how STP or RSTP works then google and wikipedia are your friends
Check out this page
http://en.wikipedia.org/wiki/Spanning_Tree_Protocol
Determine the least cost paths to the root bridge.
The computed  spanning tree has the property that messages from any connected device  to the root bridge traverse a least cost path, i.e., a path from the  device to the root that has minimum cost among all paths from the device  to the root. The cost of traversing a path is the sum of the costs of  the segments on the path.
The table below shows the default cost of an interface for a given data rate.
Data rate STP Cost (802.1D-1998) RSTP Cost (802.1W-2001)
4 Mbit/s2505,000,000
10 Mbit/s1002,000,000
16 Mbit/s621,250,000
100 Mbit/s19200,000
1 Gbit/s420,000
2 Gbit/s310,000
10 Gbit/s22,000
So in your case cost of a is: 19 and cost of b is: 2 x 4  + 100
Cheers,
Michel
...what Michel said (assuming the root bridge is reachable using BPDUs up both paths).
