09-09-2013 10:48 AM
Anybody seen a supported device list for the 2.0 release? I had heard they were adding the ASAs and maybe fixing some stuff with the Nexus monitoring also.
If this posts answers your question or is helpful, please consider rating it and/or marking as answered.
Solved! Go to Solution.
09-09-2013 11:02 AM
I haven't gotten to upgrade my lab yet but from the release notes, it appears you need to call up the supported devices from PI itself:
To view the list of supported devices in Prime Infrastructure:
Step 1 Log in to Prime Infrastructure.
Step 2 Switch to the Lifecycle view (if applicable).
Step 3 Click the question mark icon (Help) at the top right.
Step 4 Click Devices Level Support.
09-09-2013 11:02 AM
09-09-2013 11:13 AM
That worked, thanks.
