Switch port interface problem
joetan1015
Is that anyone know what is the protocol that leads to port 0/2 of Switch1 connecting to Switch0 is turned off? (Is that regarding to STP?)
And how to know the protocol determines which port on which switch device should be turned off?
It looks like spanning tree for sure unless the interfaces are configured as part of a port channel. As shaps mentioned, check the spanning tree output but it looks like Fa0/2 on switch1 is in a blocking state.
5 Replies 5
Dennis Mink
depends on the port config, buut check speed and duplex settings are the same at both end and check if tthe port has not gone into err disable mode
please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
I try to check the status of port with
show interfaces fa0/2 status
but invalid input detected at status.
Please help...
You mentioned spanning tree have you checked what the output of show spanning tree shows
Yes, Fa0/2 was in blocking state. Thank you very much.
I had configure the link aggregation and the Fa0/2 was back to green.
