10-12-2016 04:20 PM
Hello, I have a 2960X stack of 3 switches.
Is there any way to use SNMP to monitor the status of the individual CPUs on each member of the stack ?
I have used the 'cisco-stackwise-mib' but there does not seem individual stats for each member CPU.
Thank you kindly.
Solved! Go to Solution.
10-17-2016 03:49 PM
Hey there,
The CISCO-STACKWISE-MIB is not meant to monitor CPU info on switch stacks; mostly ports/power/role info.
The CPU info is provided by the CISCO-PROCESS-MIB. It provides however, info per-CPU in each device, not a single CPU value per device. The objects below might be useful:
cpmCPUTotal5secRev - 1.3.6.1.4.1.9.9.109.1.1.1.1.6
cpmCPUTotal1minRev - 1.3.6.1.4.1.9.9.109.1.1.1.1.7
cpmCPUTotal5minRev - 1.3.6.1.4.1.9.9.109.1.1.1.1.8
cpmCPULoadAvg1min - 1.3.6.1.4.1.9.9.109.1.1.1.1.24
cpmCPULoadAvg5min - 1.3.6.1.4.1.9.9.109.1.1.1.1.25
cpmCPULoadAvg15min - 1.3.6.1.4.1.9.9.109.1.1.1.1.26
Hope this helps.
Luis
10-17-2016 03:49 PM
Hey there,
Hope this helps.
Luis
10-18-2016 04:14 PM
Hello, thanks for that.
How do I interpret the results i.e. they are not in percentages - they show as a scale of 1.0 - 4.0.
Thank you.
10-19-2016 02:09 PM
Can you please share the output of the cpmCPUTotalTable (1.3.6.1.4.1.9.9.109.1.1.1) that you get? The OIDs are meant to be percentages based on their definition.
Luis
