Switches and Routers CDP neighbours on Cisco Prime Infrastructure 2.0
fuhrersk8
Participant
Participant
Hello Forum Team!
    Does Cisco Prime Infrastructure 2.0 allows to obtain the CDP neighbors data from switches and routers? I've seen it does but for Wireless controllers only.
Thanks in advanced!
AFROJ AHMAD
Hi ,
If you are talking about the topology MAP like we have in LMS  then unfortunately it is not available now , it is been commited to be in PI 2.2  ( tentative date of release is Oct'2014)
Thanks-
Afroz
****Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi ,
Thanks-
Afroz
   Hello Afroz and thanks for your reply. I am looking for the CDP neighbours list of each device. For example, the WLCs have an option to display its current neighbours under Device Details-->Ports-->CDP Interface neighbours. Ports Ports .
Thanks again for your support!
