Switches to Routers connection on CiscWorks
itssnsu07
On Campus Manager, topology view, the routers are displayed disconnected from the switches, why don't i see the link between the switches and router?
Thank You for your time and assistance,
Genet .
6 Replies 6
frankzehrer
Level 4
Level 4
Hi Genet,
what Version of CM you are uning?
Do you have CDP enabled on the devices?
Best regards,
Frank
Thank You very much, frank. I am using CM ver4 and yes have enabled cdp.
Thank You again!
Genet T.
Hi Genet,
what subversin? You need to be more specific.
4.0.0 or 4.0.3 or 4.0.9?
Frank
Hi Frank,
It is 4.0.3
Genet
Hi Genet,
therefore i assume you are running LMS 2.5.1.
There were issues like that in the older CM Versions on the 2.5.x train and should now be fixed.
You should obtain the free Upgrade to LMS 2.6 and then upgrade to CM 4.0.9.
Best regards,
Frank
Hi Frank,
True i am running LMS 2.5
I will upgrade both and check the outcome.
Thank You so much for your time and Help.
kind Regards,
Genet
