Sync Archive failed 3850 switches - prime lms 4.2.5
Anas Hijjawi
We are running Prime LMS 4.2.5, we added 3850 switches from the same model and same hardware, we found that the failed devices have different OID.
failed: 1.3.6.1.4.1.9.1.1745
successful: 1.3.6.1.4.1.9.1.1641
Is there any workaround for this problem
Thanks, Anas *--* Please rate the useful post,its free ;) *--*
Vinod Arya
Can you manually poll both the devices for snmp object sysObjectID and share result?
It seems one of the device is running as a Stack as first one is an OID for a stacked 3850. Also check the device for show snmp sysobjectid command and share results.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
thanks Vinod, can you tell me the steps to do, also please note that we are running lms on windows, both devices are stacked
it should be like this:
