Beginner
Synchronization between CISCO WSA and SMA
Hi there!,
I would like to know why in the SMA's system status - Security Appliance Data Transfer Status - Connection Status, there is a message that says FILE TRANSFER FAILURE
Name      Type                   Status                                      Services
WSA        WEB     FILE TRANSFER FAILURE     Centralized Configuration Manager
1 ACCEPTED SOLUTION
VIP Advisor
Re: Synchronization between CISCO WSA and SMA
is this new setup, so setup correctly. (is there any upgrades ?)
If the working one failed, check the connectivity.
BB
*** Rate All Helpful Responses ***
1 REPLY 1
VIP Advisor
BB
Content for Community-Ad
July's Community Spotlight Awards
