Syslog Messages106006
Umair Yaseen
On ASA 8.2 I am receiving bulk error notifications about 32K error messages in few hours for the syslog event ID 106006 The Message is as below ""Deny inbound UDP from 10.107.0.32/56506 to 10.113.13.67/514 on interface inside"" Someone please explain in details about above message and how can I stop this? As per my knowledge 10.107.0.32 IP is outside host & is trying to access inside host 10.113.13.67 ***Please also note that there is no host with the IP 10.113.13.67 inside our LAN
Seb Rupik
Hi there,
This message is simply telling you that no security policy (ie ACL) has been configured to permit this traffic, so it is being dropped.
https://www.cisco.com/c/en/us/td/docs/security/asa/syslog/b_syslog/syslogs1.html#con_4768882
You can filter out these messages with the following config command:
no logging message 106006
Since you say you are seeing a great deal of these messages, I suggest you track down 10.107.0.32 (it is a private address so should reside somewhere on your company network) and determine why it is trying to reach 10.113.13.67 ? Is 10.113.13.67 a syslog server that should be receiving logs from 10.107.0.32, in which case perhaps you should explicitly permit the traffic though.
cheers,
Seb.
