Syslog Time Problem
xshant
Level 3
Level 3
Dear *,
I have a weird problem about syslog time. I get correct syslog timestamp on the router and syslog_info but when i go on RME to see report i get incorrect time. Infact time is future, plz check time stamp on below of the same message in syslog_info, router and RME report?
Output from syslog_info
Oct 28 09:04:02 08C0-PE012-001.mpls.ae 45: 000081: *Oct 28 09:04:01.220 AST: %SONET-4-ALARM:  POS8/1/0: SLOS cleared
Oct 28 09:04:02 08C0-PE012-001.mpls.ae 46: 000082: *Oct 28 09:04:01.316 AST: %SONET-4-ALARM:  POS8/1/0: B1 cleared
Oct 28 09:04:02 08C0-PE012-001.mpls.ae 47: 000083: *Oct 28 09:04:01.316 AST: %SONET-4-ALARM:  POS8/1/0: B2 cleared
Oct 28 09:04:02 08C0-PE012-001.mpls.ae 48: 000084: *Oct 28 09:04:01.316 AST: %SONET-4-ALARM:  POS8/1/0: B3 cleared
Oct 28 09:04:02 08C0-PE012-001.mpls.ae 49: 000085: *Oct 28 09:04:01.720 AST: %LINK-3-UPDOWN: Interface POS8/1/0, changed state to up
Oct 28 09:04:03 08C0-PE012-001.mpls.ae 50: 000086: *Oct 28 09:04:01.720 AST: %IFDAMP-5-UPDOWN: interface POS8/1/0 update IP Routing state to UP, interface is not suppressed
Output from Router
Report from RME
5. xxxxx xxxxxx Oct 28 2010 22:04:01 SONET 4 ALARM POS8/1/0: SLOS cleared *
6. xxxxx xxxxxx Oct 28 2010 22:04:01 SONET 4 ALARM POS8/1/0: B1 cleared *
7. xxxxx xxxxxx Oct 28 2010 22:04:01 SONET 4 ALARM POS8/1/0: B2 cleared *
8. xxxxx xxxxxx Oct 28 2010 22:04:01 SONET 4 ALARM POS8/1/0: B3 cleared *
9. xxxxx xxxxxx Oct 28 2010 22:04:01 LINK 3 UPDOWN Interface POS8/1/0, changed state to up *
10. xxxxx xxxxxx Oct 28 2010 22:04:01 IFDAMP 5 UPDOWN interface POS8/1/0 update IP Routing state to UP, interface is not suppressed *
any ideas people?
Thx,
Aamir
7 Replies 7
Gaganjeet Chug
Level 9
Level 9
Hi Amir,
Please go through this link and adjust the timezone of the devices if the syslog reports are showing different time zone of the syslog messages in the
syslog reports.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00807ca437.shtml#ios
It all need to be done
clock timezone CST -6
clock summer-time CDT recurring 2 Sun Mar 1:00 1 Sun Nov 1:00
ntp server 10.100.1.9
and the output should be
ENET-4507R-CORE#show clock
14:37:46.525 CDT Tue May 12 2009
Gaganjeet
But i am getting the right timestamp on the router and on the syslog_info file on the solaris server? just in the RME reports its showing weird time?
Aamir
HI Aamir,
Kindly enable the debugging for Syslog from RME > Admin > System Preferences > Application Log level setings > Syslog Analyzer > DEBUG > APPLY.
Generate few syslog and show the following output.
1> Logs generated by device
2> Same syslog in syslog_info
3> AnalyzerDebug.log
Note :- Kindly delete any sensitive information from the debug logs.
Gaganjeet
Dear,
I was able to solve the problem. My routers had "service tmestamps log datetime msec localtime show-timezone" so when i removed the "show-timezone" it solved the problem and RME shows the correct time now. Although i dont understand why "show-timezone" was creating problem.
However i just noticed something, when i did clear ip bgp * i get tthe syslogs in syslog_info and in RME report no problem but when i do clear ip ospf process, no syslogs in the syslog_info and RME report?? Looks like the router is not sending OSPF syslogs? how is that happening?
Aamir
Hi Aamir,
If you are not able to see the log into syslog_info then I think its device side issue. Kindly try to reproduce the issue with packet capture and check if device is actually sending syslog to device or not. If not, then need to diagnose it from device side troubleshooting.
Gaganjeet
Ok this is what i found, Lets say we have two routers A & B. when i do clear ip ospf process on router A
, no syslog report for router A however when i check syslog report for router B i get adj loading fulll syslog, and vice versa. Meaning I only get loading full message but not from the router where i executed the command but on the adj router??  Is this normal?
Aamir
Hi Aamir,
Kindly open new thread for Router side issue. The point is we must have syslog into syslog_info file so that CiscoWorks process it according to Syslog filter setings.
Gaganjeet
