TACACS vs HWTACACS
CSCO12006174
Does anybody know if HWTACACS (Huawei TACACS) is 100% compatible with TACACS? Are there some differences? Thanks...
Not_light
HWTACACS is compatible with TACACS+ to some degree, but not 100%. HWTACACS and TACACS+ have identical processes and implementation mechanisms for authentication. That is, they are compatible with each other at the protocol layer. I found this at Is the HWTACACS and TACACS+ compatible?
Hope this could help you.
