TCL interpreter not terminating
cgrodde
Hi everbody,
i'm trying to run the little script bellow via cut&paste....
However, the next command "tclquit" after calling the proc isn't running! Nor any other command...
Is there a trick to terminate such cut&paste proc's?
( in my case i need to work with cut&paste and proc's)
tclsh
proc foo {} {
  puts "hello"
  return -code ok
catch {foo} result
tclquit
Joe Clarke
I believe what you're seeing is related to CSCsy69914, and an upgrade to 12.2(55)SE3 will correct it.
cgrodde
Shouldn't add that i'm trying 122-53.SE1. But i thing it's release independant....
Joe Clarke
Your are right!
I've tested the script on a 6500 box running 122-33.SXI5 with no problem!
Many thanks
