TCL MTU Discovery
Cory Anderson
Hi All,
I'm looking for a scalable solution to find the MTU of a path between tunnel endpoints and configuring the Tunnel IP MTU and TCP MSS accordingly. I can use the extended ping with df-bit and sweeping in size, but I'm hoping to leverage TCL so I can push this for multiple tunnels/devices at a time.
Any ideas?
Cory
Try
Path MTU discovery,
 You may find this interesting.
https://blog.ipspace.net/2007/10/tabular-display-of-interface-mtus.html
With some ajustment, you can run it across.
