Hi:
I worked on Cisco MWR2941,the version is below:
NATLIS_2941_3#show version
Cisco IOS Software, 2900 Software (MWR2900-ADVIPRANK9-M), Version 12.2(33)MRB4, RELEASE
SOFTWARE (fc1)
I also want to find out the direct relationship between E1 port and TDM(cem)model from MIB.which MiB can store the data of TDM ?
do you know where can find out the direct relation between "E1 0/1" and "cem 0/1" in Cisco MIB?
the reason is below:
as customer's need,we(CiscoMWR2941) need to add a function on configure
ATM or TDM(cem) mode to E1 interfaces and upload relative information
from MIB;
now,we can configurate these two modes by command.and we had already
found the direct relation between "E1 0/1" and "ATM 0/1" ,but we can't
find the direct relation between "E1 0/1" and "cem 0/1"(TDM).
####if set the mode of E1 to "ATM",
we can see from ifStackTable of IF-MIB:
IF-MIB::ifStackStatus.25.23 = INTEGER: active(1)
Here '23' is the ifindex of E1 0/1, '25' is the
ifindex of ATM0/1
then we can also see from ifTable:
ifIndex ifType ifDescri
23 ds1 E1 0/1
25 atm ATM 0/1
we could find the uping entry in ifdescri MIB entry
and know this E1 port which ifindex is 23 in ifStackTable is in ATM
mode.
####if set the mode of E1 to "TDM",then we can see from
if table:
23 ds1 E1 0/1
154 other cem 0/1
we can't find the direct relation between "E1 0/1" and
"cem 0/1" as ATM mode. we had tried our best to resolve this problem,but
still can't find.
sun nan
