Temperature Threshold
gsantini
Hi. I want to modify the temperature threshold on Router 7609 and Catalyst 6500. I need to make some test with temperature alarm and I need to modify these parameters. I really don't want to put these equipment under critical conditions. I just want to modify the temperature threshold. And then, I need to configure the syslog messages to be sended at the syslog, and configure the shutdown parameters to stop the equipment.
Brgds
David Stanford
There's no way to do this other than by having the temperature of the device change. The thresholds look at actual temperatures and there's no way to modify these temps (fake them) for testing.
guruprasadr
Level 7
Level 7
HI, [Pls Rate if HELPS]
The below link will take you to CSICO - Embedded Event Manager (EEM) Scripting Community.
EEM is a flexible system designed to customize IOS for Automate tasks, perform minor enhancements and create workarounds.
http://forums.cisco.com/eforum/servlet/EEM?page=main
The Community has many pre-defined Scripts available for many CISCO Administrative requirements.
Hope I am Informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
