Beginner
Terminal Sever - ASA Console Access
I have a Cisco router running as a Terminal Server for OOB console access to various Cisco devices.
I'm seeing an intermittent issue with ASA console ports where they seem to lock up. When this happens I can see output on the console port, but I can't input anything. A reboot of the ASA cures the problem for a while but the issue returns.
Kind Regards
Terry
2 REPLIES 2
Hall of Fame Master
If you have low level logging
If you have low level logging turned on for your ASA console, you could be overrunning the input buffers on the console server.
Beginner
Hi Marvin
Hi Marvin
Thanks for your reply.
I don't have console logging enabled on the ASA's.
When I look at the Terminal Server lines connected to the ASA's I am seeing noise and overruns, however, I am also seeing these on other lines that are working ok.
KR
Terry
Content for Community-Ad
July's Community Spotlight Awards
