What is the best tool to manage 25 2960 switches, for example I create single user on each switch when needed, and many more similar task are solved similiarly. I need an advice what free tool can I use for that?
For those repetitive tasks the best is to use script but without some tool you would need to connect to each switch separatelly. Im not aware of free tool.
