to to import network devices to CW LMS 3.1
baotran09
I have an excel spreadsheet which contains a list of network devices.
I understand that you can import to CW by converting it to csv or xml
How do I convert xls to cvs or xml?
Thanks in advance,
Michel Hegeraat
Level 7
Level 7
Well,
File save as  select type .csv
But better create on device manualy in the lms gui, do an export to csv to get the file format and all the right columns
Cheers,
Michel
