Traditional ACL vs Zone Based FW
BHPCI_2
I have a 3845 ISR that I have been managing for a couple years that has a traditional ACL based config.  We just purchased a new 3845 for redundancy and it arrived with the zone based config from Cisco.  Any opinions on whether I should take the existing router to a zone based config or should I configure the new router with traditional ACL config that I am more comforatable with?
ccube
If there was the option to use a Zone based FW or just straight access lists then surely the Zone based FW would be considered a better option as it has more features than just permit or deny. The Zoned based FW will also inspect traffic and block any traffic with malicous code for example. I am not an expert in this arena, but based on Security exam topics and other publications, the FW approach seems to be gaining traction versus managing ACLs alone. Although, ACLs will always have their place in the network...
The choice is based on your comfort level, but both are viable options...
BR,
Cary
