03-01-2015 01:59 AM
Hello community,
I have an Catalyst 3750X and a SG300-28P Small business switch.
I got it to work to connect both on a RJ-45 connector (Copper) and configured trunk on both sides.
Configured vlan and it is working flawlessly.
Now I am coming to my production environment there I don`t get it to work :-(
The difference is, that in production the data goes over a fibre-cable. Both sides of the fibre has a media converter.
On one side we have a media converter called "Converter Chassis CR-1600B" and on the other side we have "HTB-1100S".
Right now the fibre channel is configured as access port. In "switchport mode access" it is working normal. When I change it to trunk, it is not working.
Can somebody help me out here
Thank you
Paul
03-01-2015 04:33 AM
Maybe on the 3750X, you forgot to use the interface command "switchport trunk encapsulation dot1q".
03-01-2015 04:54 AM
Sadly not.
As I wrote I have tested it successfully in trunk mode without the fibre cable between.
Can it be that the media converter don`t forward trunk? (When this sounds now completely crazy I am sorry I don`t have a clue about fibre)
I have also tested two new gigabit media converter from d-Link but they cannot at least connect to each other. Can it be that the fibre cable is crap? With the old media converter 100FastEthernet I got at least a "access"-connectivity.
03-03-2015 01:31 PM
Post the output to the command "sh interface trunk".
