Trunking an ip addressed inside interface on Firepower 2130
jreynolds4
My network endpoints use the IP addressed vlans on my core cisco layer three core switch as their gateway addresses. i.e.- vlan 11 endpoint address 192.168.11.3/24 with gateway 192.168.11.1/24 (vlan ip on core) and vlan 12 endpoint address 192.168.12.3/24 with gateway 192.168.12.1/24 (vlan ip on core). These vlans are then interconnected. I am attempting to create a path to the internet using the gateway of last resort out of the switch 0.0.0.0 0.0.0.0 10.2.2.1. 10.2.2.1, security zone "InsideTrunk," is the address of a physical inside interface on my Firepower 2130. I have created Access control policies to allow 192.168.11.0/24 and 192.168.12.0/24 from "InsideTrunk" to Outside on the Firepower. Also, the proper auto NATs for both subnets have been created. The endpoints are unable to reach the internet. All I am trying to do is create a transport network. Does anyone have an idea of what I am missing? I have attached the trunk config from the core switch.
45 Replies 45
Not only route' the points that I mention before
In FTD config l3 interface connect to SW give it IP like 100.0.0.1 (any unused IP)
In SW
Interface x/x
No switchport
Ip add 100.0.0.2 /24
No shut
In SW defualt route is enough'
Ip route 0.0.0.0 0.0.0.0 100.0.0.1
In FTD
You can use one or multi object' each object have subnet of one vlan
Route <interface connect SW to FTD> <object of vlan's> 100.0.0.2
Then you sure need NAT
Nat (inside'outside) abd use object you use in route in NAT
That It
Note:- ftd dont have security level so you need ACL allow traffic from and to vpan subnet
MHM
