Trunking Ports on catalyst 4506
Stallergenes
How can i configure on the 4506 a trunk mode for 2, 3 ports, cause i want to make a link agragation between two switches, on the other one which is a dell i already configure two statics ports for the agragation.
Thank you.
Joey
williamsdo
Level 3
Level 3
Hi, you can configure trunking on one or morw switchport, by default they carry traffic for all vlans. use etherchannel or port channel to group the port together for load balance and combined bandwidth. Have a look at the documents below.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/12ew/configuration/guide/layer2.html
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/7.1/configuration/guide/channel.html
Thank you, i'll take a look.
Have a good day.
