RahmaSallm
Beginner
Turn of DNS in Prime 3.9
Is there any way to turn off DNS completely in Prime 3.9?
In release notes it mentions only that DNSsec in enabled by default and one can disable it. But we want to turn off the DNS feature completely.
1 ACCEPTED SOLUTION
 -  I would consider DNS services very essential in all sorts of tasks and including critical tasks Prime has to perform.
 M.
5 REPLIES 5
marce1000
VIP Advisor
 - Vary strange request , can you elaborate on the needs of this ?
 M.
It is just something our end customer is wondering about. They had issues with identifying the right DNS server in Prime. But now that that is solved their NOC is wondering if DNS functionally can be at all stopped in Prime.
 M.
Thank you for your answer
balaji.bandi
VIP Master
Not sure disable DNS make the right choice here? how will the device names resolve?
BB
How to Ask The Community for Help
