Unable to activate monitor capture - cisco ASR1001
Gabriel Gabriel
Hi Guys,
I need to troubleshoot an package loss issue and for that I would like to use "monitor capture" but it just do not start, see bellow.
ASR1001#sh monitor capture cap_out
Status Information for Capture cap_out
  Target Type:
   Interface: GigabitEthernet0/0/1, Direction: both
   Status : Inactive
  Filter Details:
   Access-list: acl-out
  Buffer Details:
   Buffer Type: CIRCULAR
   Buffer Size (in MB): 10
  Limit Details:
   Number of Packets to capture: 0 (no limit)
   Packet Capture duration: 60
   Packet Size to capture: 0 (no limit)
   Maximum number of packets to capture per second: 1000
   Packet sampling rate: 0 (no sampling)
ASR1001#monitor capture cap_out start
Unable to activate Capture.
Did anyone face that?
nagykolozsvaria
I had this problem too.
When I cleared the "log" extension at the ends of the access-list lines then the problem have been settled.
Thanks, worked for me.
I had the same issue.
Mine was caused by trying to capture an interface belonging to a port-channel.
Capturing on the port-channel instead of the physical interface resolved this.
Mine was caused by trying to capture an interface belonging to a port-channel (on a 4500X).
