Uninstallation Procedure for LMS
helexis
I would like to uninstall LMS and install fresh now that I have had a little more experience with the setup.
Is a simple uninstall via Add/Remove Programs sufficient? Or is there a known cleansweep procedure I can follow? Or maybe I just bite the bit and...gulp...format the drive for the best results? Any advice? :)
Thanks in advance!
Usually, yes. Sometimes, if the installation was originally bad, a typically uninstall will not work. In that case, there is a utility called clean_system.exe available from TAC which will purge LMS from a server.
helexis
Ok so I found the procedure outlined in this document. Is this usually sufficient?
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/lmsig.pdf
