Highlighted
Beginner
Update Firmware on Cisco Switch SG350X-24P
Hi folks,
i would like to update my new Cisco SG350X-24P switch. I'm quite new to this. When i look at the Cisco homepage and select my model, then "Downloads" i can see several firmware download possibilities (e.g. 2.5.0.83 and 2.4.0.94) as "Switch Firmware". But i also see above "Managed Switch MIB" with 2.4.0.91 and 2.3.0.130 versions.
So..first question: May i always take the latest one and just upload it on the switch?
Second: What is MIB and where is the update possiblity for this on my switch?
Thanks in advance!
Everyone's tags (1)
1 ACCEPTED SOLUTION
Rising star
Re: Update Firmware on Cisco Switch SG350X-24P
 - You are encouraged to use the latest switch firmware. SNMP MIBS are not installed on the switch but used for SNMP Manager Software solutions where they can be imported for monitoring your device (e.g.).
 M.
2 REPLIES 2
Rising star
 M.
Beginner
Great, thank you for your short and precise answer!
Content for Community-Ad
July's Community Spotlight Awards
