Update jrmuser.properties after hostnamechange.pl?
yjdabear
With LMS 3.1, does jrmuser.properties need to be manually updated after running hostnamechange.pl? The former still has the old hostname appended in there. Or does it get updated automatically once I start dmgtd?
Yes, it must be unique. If you have two servers, serverA and serverB, you must use a unique jrm ServiceName on both servers regardless of the LMS version. Both ServiceNames MUST NOT contain dots (thus the hostname component must be the short hostname).
Joe Clarke
It is not necessary. All that needs to happen is that the jrm service name must be unique on the network. If you would like to update this file, be sure you ONLY use the short hostname. If you use the FQDN, this will break jrm.
Does it only have to be unique across two same-version LMS boxes? What about one LMS 2.6 (ServiceName=JrmServiceManager_hostnameA.fqdn.com) and one LMS 3.1 (ServiceName=JrmServiceManager_hostnameA)?
