08-26-2009 04:26 AM
We've provided "remote upgrade" from LMS 3.1 (Win 2003) to 3.2 (Win 2008 64bit). The restoration of backup directory ended by message
ERROR: doRestore of [Resource Manager Essentials] had some errors.
I've checked all three log files mentioned in documentation
NMSROOT\log\restorebackup.log
NMSROOT\log\migration.log
NMSROOT\log\rme_base.log
but I haven't seen anything suspoisious. Is it a "false positive", or should I check another file ?
Thanks in advance.
Jan Klicka, SITMP
08-26-2009 07:39 AM
Please post these log files.
09-02-2009 06:15 AM
09-02-2009 09:06 AM
There appears to be a problem with the backup. Within it, the RME data directory is missing (from D:\CW2000\files\rme on the old server). I recommend you try taking a new backup from your old server, and try to restore it. If that fails, you should open a TAC service request so the contents of the backup can be analyzed.
