Upgrade LMS 3.1 -> 3.2 - error in data restoration ?
jan.klicka
Beginner
Beginner
We've provided "remote upgrade" from LMS 3.1 (Win 2003) to 3.2 (Win 2008 64bit). The restoration of backup directory ended by message
ERROR: doRestore of [Resource Manager Essentials] had some errors.
I've checked all three log files mentioned in documentation
NMSROOT\log\restorebackup.log
NMSROOT\log\migration.log
NMSROOT\log\rme_base.log
but I haven't seen anything suspoisious. Is it a "false positive", or should I check another file ?
Thanks in advance.
Jan Klicka, SITMP
3 REPLIES 3
Joe Clarke
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Please post these log files.
here you are. Sorry for delay - i had to be almost a week off.
"Migratition.zip" contains three log files mentioned above, "window.log" is output of the restore command on the screen.
Thanks in advance
Jan Klicka, SITMP
Joe Clarke
There appears to be a problem with the backup. Within it, the RME data directory is missing (from D:\CW2000\files\rme on the old server). I recommend you try taking a new backup from your old server, and try to restore it. If that fails, you should open a TAC service request so the contents of the backup can be analyzed.
