Upgrade Prime Infrastructure v1.2.1.012 to v1.3.0.20
stefan.vanya
is there any patch for upgrade from v1.2.1.012 to v1.3.0.20?
Or I can install upgrade directly?
St.
Marvin Rhoads
If you're currently on 1.2.1.012, you can upgrade directly. (Reference)
But there is:
IMPORTANT: You MUST patch your existing system prior to using this upgrade installer. See appropriate patches under Prime Infrastructure Patches.
And in the table:
f your existing system is...
Download this point patch file
Cisco Prime Network Control System 1.1.0 (1.1.0.58)
ncs_patch-1.1.0.58-upgrade-12.tar.gz
Cisco Prime Network Control System 1.1.1 (1.1.1.24)
ncs_patch-1.1.1.24-upgrade-12.tar.gz
Prime Infrastructure 1.2 (PI 1.2.0.103)
pi_1.2.1.12_update.tar.gz
Last row doen't match current version (1.2.1.012)
St.
Your existing system is already 1.2.1.012. The point patch shown in the last row of the table above would bring it up to that patch level if it wasn't already there.
